unconfigure process group
Description
This command restores the default settings for memory and CPU limits for both the "Vital" and "Other" process groups.
Syntax Description
N/A.
Default
None.
Usage Guidelines
If one of the process groups is already consuming more memory than the default limit, an error may appear and the command may not execute successfully:
Warning: Unable to restore memory limits to default values. One or both of the groups are already consuming more memory than their default limits (95% for “EXOS” and 5% for ”Other”). CPU limits have been restored to their default values.
The following example restores the default memory and CPU limits of the process control groups:
This command was first available in ExtremeXOS 22.2.
Platform Availability
